1 room radiant??
Tom Meyer
Member Posts: 300
Yes, depending upon local code, he can use A water heater. As to whether he'd want to use HIS water heater is a completely different issue.
It's not a good idea to use a water heater for dual purpose (heating and DHW) without some serious piping and safety considerations.
Have him think in terms of getting a seperate water heater for the addition. In the long run, it'll probably be cheaper and alot safer.
Senior Designer/Trainer
Precision Hydronics
www.precisionhydronics.com
Precision Hydronics
1 room radiant
A friend is building an addition- family room. He would really like to try radiant floor. Is there any way to do it economically? Could he use his hot water heater as a boiler and make 1 zone? He has forced air right now. Thanks.0 -
I say yes to both questions, but
I am in Ohio where a lot of things that are possible have yet to be outlawed. He might have to make a choice of which demand to take care of first at shower time.
Mark
how big a room?
depening on the size he could use a small seperate heater.If he uses the present heater he needs to use a heat xchanger to seperate the zone from the potable water.Could/would be a bacteria issue.Lots of ways to make radiant work.Is there some more info. kpc0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
