Floor Warming in Showroom
Rob Garcha
Rob Garcha Member Posts: 12
I am going to be installing a floor warming system in a wholesalers showroom soon using Wirsbo Quik Trak. It is going in the childrens playroom over an existing concrete slab. My plan was to glue down 1/4" plywood to the slab, install a layer of padding (like the stuff used under Pergo flooring) Put Quik Trak over it then a sheet of underlayment, topped with glue down carpet. We are trying to keep the floors profile as low as possible. Does any one have any suggestions or a better way of doing it. I would appreciate any ideas.
Rob Garcha
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    warmfloor showroom
    Leave a corner covered with heavy glass or lexan so customers can actually see what is under the floor. Don't forget to put a heated towel rack in the ladies's room!
