New oil fired boilers
Rob_6
Member Posts: 4
I'm in the market for a new boiler. House size 1800 sqft,2 levels,3 zones, base board.What's the best company(peerless,Weil Mclain,Burnham).Should I go w/3 circulators or 1 with automatic valves????
They Are All......
good. It's like Ford , Chrysler, GM. It , to me, would depend on what my supplier stocked and what I got the best support on. What your contractor preffered. The zone valves would use less electricity, but it depends.How about Viessmann or Buderus? Outdoor reset, TRV's. What type of fuel? What type of radiation? What climate, it all depends0 -
New Boiler
What would you put in your house peerless or burnham?
What type of circulation would you use 3 seperate circulators or 1 ciculator w/valves.
I live in NY ,3 zone oil boiler w/coil for hot water,baseboard heat.
Thanks,0 -
Boilers
I would put in a Buderus with a Riello and use circulators and flowvalves over zone valves in my home.....But if you give me a choice between Peerless and Burnham , I would lean toward Burnham with their great service...0 -
New boilers
I would put in......
I would put in a Biasi SG series. surpasses Buderus in
combustion and Thermal Heat Transfer Efficiency
Jed0 -
Any of the above will........
work fine IF installed correctly. I would add Crown, which is my choice, into the mix if you are looking for domestic iron. Also, add an indirect water heater for optimal hot water production. When it comes to zoning, one circulator and three zone valves would be a good choice. An off the shelf pump, e.g. Grundfos 15-58 will be more than enough pump for your entire house.
hb
Link
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
All of the above..............
will work adequately IF they are installed properly. I would add Crown, which is my favorite, into the mix when it comes to domestic iron. Zone valves and a single pump, e.g., Grundfos 15-58 is more than enough pump for your entire home.
hb
http://climatecadvanced.com/Projects/Barn/barn.html
Bill said it.
Rolls Royce makes an awesome car, but just try to find parts for it in my area. When your heat is down you need it replacement parts / service pronto. I live in upstate NY, below zero right now. There are 3 suppliers around my area that carry my brand of boiler.0 -
Jeffrey
Have you used any Vitorond's? You know, the silver and orange company.
We just went back and checked a VR2-50 we installed in a church last fall. It was nearly spotless inside. No soot, nyet, nada, zero. A trace of white ash in the bottom of the combustion chamber. Combustion efficiency last fall 88.6%, same numbers now, exactly with 0 smoke. Like about all their other stuff, it's a truly fine piece of equipment. With the boiler running 150* water today, you could hold your hand on the flue pipe without instantly burning it.0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 891 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
