prob after taking off a rad
alex sharp
Member Posts: 2
Hi,
I wonder if anyone could offer a suggestion for a problem I have encountered after taking a radiator off to decorate.
I have encountered what appears to be a massive airlock in the system , Ive tried opening the bleed valves on the rads , undone the bleed valve on the water cylinder all to no avail , someone has suggested it might be an airlock in the cold water feed pipe , but I have had a look at it and there is no apparent means of bleeding air from this pipe.
Help please!!
Alex.
Help please!!
Alex.
Could it be
a single loop system? Which means the water flows from one to the next, and by removing that one water can't flow. John@Reliable0 -
Hi john,
Yes it is a single loop system but I have put the rad back on now , if that was the case though would the rads before the one I took off get hot? as Im getting nothing.
Thanks in advance for your help0 -
how
old is the fast-fill (water feed)valve? is it feeding? They love to plug with rust and crap.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 926 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
