Add radiator to hydronic system
Dan Farnsworth
Member Posts: 1
Where can I find out what safety valves, gauges, etc (if any) I should use on a radiator circuit I want to add to my planned (not yet built) hydronic system?
The heat source will be a wood stove with copper tubing as a heat exchanger, so I know that will be less predictable than a boiler. The hydronic part is designed by the good folks at Radiant Floor Co. so I know what mixing valves and temperature/pressure gauges I need there.
Should I install a cutoff valve before or after each radiator, and do I need a safety valve before or after? I can't find information on this anywhere else.
Dan Farnsworth
Dan Farnsworth
wood stove????
Dan, I think you're looking for trouble if your description is accurate. Using a wood stove and a copper coil can lead to big trouble. The wood stove is going to be a constant source of heat and will be quite difficult to control. If you're not heating a large volume of water, I would consider another source of heat. We've seen a lot of this "jury rigged" setup here in Maine over the years and it usually leads to ruptured coils, failed safety valves and floods from them, and a lack of any control. You simply can't turn off the heat when the system reaches high temp.
Please think this one over very carefully before proceeding.
Have a professional help you.
Since it's not built yet, you still can have a certified, competent, and experienced hydronics contractor help you come up the most efficient, safe and well-designed system.
You'll save yourself alot of needless grief and expense.
Senior Designer/Trainer
Precision Hydronics
www.precisionhydronics.com0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 940 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
