LINE VOLTAGE T-STATS
JIM F._2
JIM F._2 Member Posts: 2
never came across digital programable line voltage thermostats?? (for electric heat)....anyone heard of a thing.looking to replace 8 t-stats from analog to digital..
thanks
jim franze
tri-city heating and cooling
  • Luke Lefever
    Luke Lefever Member Posts: 62
    I'm not aware of anything- we had a job recently where the customer wanted to control radiant tube heaters with a progammable thermostat.... ran low voltage thermostat to fan control relay to switch the high voltage to the heater. Works great- no fancy wiring and parts are available anywhere. Good luck, Luke Lefever, Lefever Plumbing & Heating, Inc. Elkhart, Indiana
  • Joe_13
    Joe_13 Member Posts: 201
    Honeywell CT1950
    Checkout:
    http://content.honeywell.com/yourhome/ptc-thermostats/CT1950.htm
    needs 208V min to operate. I never found a 110V model.
    Available in home centers.
    hot_rod Member Posts: 24,567
    Check out
    Watts Radiant 120 V 16 amp digitals stats. Used for their electric radiant mats. Available in programable or non versions. They also have a floor sensor, if needed.
    hot rod
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    Programmable electronic stat
    Try the Honeywell T4700A1016 (SPST switching) or the T4700B1014 (DPST Switching). Both have either 7 day OR 5-1-1 programming, rated for 240 volts. Available from any Honeywell distributor.
    Go to http://hbctechlit.honeywell.com for a spec sheet.
