2\" Union on Steam Riser
Tony_6
Member Posts: 2
We have to move an exposed two-inch steam riser to a new location inside the wall. This is a one pipe low pressure steam heating system. The architect doesn't want a union behind the wall. What would you use instead, staying with the same black pipe, and is a union the wrong fitting in the first place?
Thanks, Tony
Thanks, Tony
moving riser into wall
we have had a butt weld connection done when its in a wall and this ensures no leak0 -
Can you put a coupling
in the wall and move the union close to the near boiler piping?
Mark
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
