what would cause cast iron to disintegrate
[Deleted User]
what would cause the iron to puff up and look similar to plywood thats delaminating. ran into this on a weil-mclain steam boiler today. it had a 3'' single front left side top discharge and the back right side of the boiler,top of the section has sprung steam from the weirdest looking ''hole''. like i mentioned, it didn't look like a hole but like delaminated wood. any thoughts on what would cause this?
We had the same problem about 5 years ago. After some research we found that the system had some leaks and was adding to much "new" fresh water. Creating some kind of oxygen depletion!0 -
Possibly
Possibly a small leak that is evaporating as soon as it comes out. Over time the section is eaten away and no evidence shows on the outside until it's too late. I've seen this kind of damage on a 66/68 series that didn't have the knockout removed over the tankless opening cover plate. The cover plate leaked and by the time rust showed at the bottom edge of the jacket, you could poke your finger through the jacket and the side of the boiler was as you described above.0 -
If you don't have enough vents
the condensate will turn to a mild acid, which can contribute to this problem.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
cast iron is certainly a
very durable product. Yet, still no match for the universal solvent, WATER. Somewhere along the line, maybe currently the fluid inside the sections has caused this attack, I suspect.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0 -
My two cents
To much fresh water. One of the first things I learned as an apprentice. We were replacing a section of a five year old steam boiler. Problem was too many piping leaks in the system and an over abundance of fresh make up water.
Scott
gerry , some boiler co's
consider more than 8 gallons of water added monthly as to much! Blowing down a lwco weekly = 2.5-3 gal. x 4 weeks = 10 - 12 gallons monthly and what about adding water @ other times? adds up quick to a rotten boiler. John@Reliable0 -
we had two pidgens in a 76
w-m they came down the chimney, the church had gone 3 yrs between cleanings no temp in the summer the moisture rotted a hole thru the two frist section...David0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
