Expansion Tank
AL_5
Member Posts: 1
Hi there.
I need some general information on expansion tanks.
In a hot water system, does the water from the expansion tank ever go back into the boiler?
Is there a special valve that purges water from the tank when the expansion tank is full?
What happens if the tank is full but it is unable to purge or release water to make room for expansion?
Thanks in advance to all those that respond.
xtanks
what type of x-tank? solid steel, or bladder?
the answer to two of your questions is the same for both type. yes, the water can get back to the boiler, from heating and expanding, the water will travel in and out of the tank and back into the piping, If the xtank is waterlogged on either type, when the water expands from heat,if sized correctly, will blow off thru the relief valve on the boiler if it exceeds 30# of presssure. the one piece steel tanks usually have a manual drain/purge valve IF PIPED CORRECTLY.0 -
Everything you ever wanted to know about expansion tanks...
and more. If you don't receive Contractor Magazine, sign up. The price is right (FREE).
Follow the links.
http://www.contractormag.com/articles/column.cfm?columnid=45
http://www.contractormag.com/articles/column.cfm?columnid=60
http://www.contractormag.com/articles/column.cfm?columnid=75
And if that isn't enough information to answer your questions, feel free to come back and ask the question a different way.
Happy Educated Hydronicing!!
ME0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
