Input on installing indirect on a steam system
Randy Berg_2
Randy Berg_2 Member Posts: 44
Been kicking the idea of putting a indirect on my Weils Mclain SGO 3 boiler. And would like feed back on how this setup works both pro and con.
  • Tom M.
    Tom M. Member Posts: 237
    Indirect on SGO
    Use 1" tapping in rear section for supply, return to front section bottom left. Important: put high limit in 3/4" tapping in left side of rear section. If you put it in a T on the supply, the burner will short cycle. Hope this helps.
  • Randy Berg_2
    Tom, Thank you, for the information.
