MM ps-802 LWC question
[Deleted User]
and it came with an electronic lwc. The part that has me confused is that i could find no probe...its a MM 802 RX2. I dont know what the rx2 part means but the device works. i drained the boiler and it shut down the fire and called to the feeder. But how does it work? its doing it without the standard probe..any thoughts?
reposting (nm)
reposting (nm)
The RX2 is a remote sensor model, follow the wiring and you should find the sensor. It could be mounted under the jacket. Hope this helps.0 -
yes it does
thanks, i will look again when i go back to skim somemore.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
