Finally / back to H2O
Jamie_6
Member Posts: 710
Since I got to be a wet head! All the sudden we had a bunch of furnaces we had to put in. Now I am nice and wet again. Got this little job 2 days ago to add some radiant in an addition that is being built!
Not to mention I just found out that I landed another BIG radiant job yesterday. They break ground June 1st.
Hope All is going well with everyone,
Jamie
Jamie
You are......
An artiste'!
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0 -
Jamie,
When I grow up I want to do work just like you!
al0 -
Al...
Thank the good lord....You'll never grow up .
Always wanting to learn and teach is an "affliction" that the best are born with. If you grow up , we'll all lose this from you !
Keep plugging brother wethead . Chris0 -
Bravo, Bravo
" Artist ,artist ".
I think we are seeing the birth of one of the greats !
Jamies you do wonderfull work. I will show this to my guys.
Thanks for the photo.
Scott
Question
Jamie, why does the primary loop go down, across and back up the right side of the board instead of just elbowing up after supplying the low temperature loop? Is there something else that will be connected down there later? Just curious. Tom M.0 -
Yes! They couldn't swing the new boiler w/ outdoor reset this year so we are going to do it next year.I was just making it easier to do true P/S when we return.
Jamie0 -
I do concrete restoration for a living so I guess you could call me a Cement Head, but I am renovating my house on Long Island and I have been studying radiant heat for the past two years or so.I've already put my 1/2" pex in my basement slab.
Hydronic radiant heat is fascinating to me, I am half way through Dan H.'s "Hydronic Radiant Heating" and I only got it a couple of days ago.I wish I could be a Wet Head.
My point is your work should be framed and hung in a museum, It's beautiful!
If you did that in my house, I would make you do it on the living room wall and leave it exposed for everyone to see.
Nice job!
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
