1/8 inch pilot tube fittings....Boilerpro
Boilerpro_3
Member Posts: 1,231
I have started to see 1/8 inch aluminum tubing used for pilot tubing. Much easier to work with than 1/4 inch. Flexible enough not to kink easily when pulling burners for cleaning and tightens up easily on pilot and doesn't turn loose when reinstalling burners. One problem though, the compression fittings that attach it to the pilot and gas valve are not readily available. I am starting to check further sources. Maybe Bill @ Honeywell can help with this.
Boilerpro
Boilerpro
- 120 Geothermal
- 169 Indoor-Air Quality
