2632ppm co level
John@Reliable
Member Posts: 379
As you can see this is a good size boiler room. The call was for a "funny smell". I walked in and turned right around to get co meter. Walked back in and found a reading of 2632ppm in the room,after shutting down boilers and venting space found a burnt out motor on the ID fan.After fixing this I also found Both boilers draft senors had been disabled,at least this explained why boiler ran with no draft. Just when you think you have seen it all.John@Reliable
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
