Munchkin 50/80
[Deleted User]
Is there anyone that has any experince with this new boiler.
To my knowledge...
it's not out yet. I could be wrong, but...
ME0 -
50/80 Munchkins
there will be two wall hung units. The Vision one controler will be applied. The smaller of the two unit's will have a BTU range of 50,000 down to 10,000 and is fully modulating is available in natural and LP gas and can be field converted. When the indirect calls it will be on priority and will modulate to a high rate of 80,000 BTU'S. It has a 5:1 ratio. One can program the duration of time you want the indirect to stay in priority mode. It will stay in this mode untill it is satisfied or it reach's the maximum time programed.
The larger of the two is the same as above except it will have a BTU range of 80,000 down to 15,000 BTU'S and when the indirect calls will go to a high rate of 110,000 BTU'S
The units should be available mid to summers end.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
