primary secondary systems
clammy
Member Posts: 3,113
was wondering seen both ways which in your opinan work better. seperate tee off primary for each defined system,ex.indirect water heater,baseboard,radiant or just one set of tee's sized for the whole sec.systems.i have usedthe first method mentioned without flow valves and experenced no ghost flows or thermal migration while i have worked on systems done with one set of tee's and had ghost flows and someamazing thermal migration.all things aside both systems had flow valves on supply and returns to theindirect water heater to prevent overheating of domestic tank just wondering if anybody else has tried these options
just looking for some input thanks
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
NJ Master HVAC Lic.
Mahwah, NJ
just looking for some input thanksR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
