What is this?
Jason_4
Member Posts: 9
What is the large pipe located in the basement floor in the picture for? Is this a toilet hookup or just another floor drain? The copper pipe in the background is the water inlet from the city.
Cleanout (nm)
...0 -
can it be used as a toilet hook up?0 -
not
if it is trapped, a double traped drain does not drain.
don't cover
what ever you do, don't cover this up or build a wall over it. it's your main sewer clean-out. if you cover this up, you can't clean main drain or sewer if it would plug-up0 -
what type of building is this ?
That appears to be about 8" in diameter. Looks like a cleanout, but have you had the top off & looked inside? Do you have any old drawings? Is there storm piping in the building, if so, is it a combination sewer or do you have seperate sanitary & storm sewers?0 -
Careful
It is likely the cleanout but could also be the weepingtile cleanout which attaches to the weeping tile around your house and drains only to ground.(Assuming you have weeping tile) If it is the result would be disasterous. If you want a toilet downstairs my advice would be to break up the floor and tie into the main line. Under no circumstances would I use this to seat a toilet0 -
If you remove
the plug and flush a toilet in one of the bathrooms and you can hear water running down the drain from the open pipe, you will know that it is connected to your sanitary system.
If that were in my area, I would say it's an end-of-line cleanout. You can use it for a toilet if it's connected to the sanitary system if you do 3 things:
1) move it to the proper rough-in location
2) vent it
3) install another cleanout somewhere to take its place
By the way, if that cleanout plug has never been removed, you may have a hard time getting it off. Most of the time, we end up cutting through the brass plug and replacing it with a well greased plastic one.
It's a floor safe
open it and put your jewelery down there!
Just kidding!Bob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
