radiator covers
Dave Mayer -3 Sons Heating
Member Posts: 59
I have a customer that is looking to purchase radiator covers. I have found a couple of sources here in Massachusetts, but, my customer wants "antique looking" covers preferrably painted. Help!!
Thank You;
Dave
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=261&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Thank You;
Dave
More info?
Can you give more of a description of what they are looking for. I have a few sheetmetal for "recessed radiators". I don't know if they'd be considered "antique looking" but they were probably made in the 40's or 50's.
If they're looking for a whole house worth, I'm sure I can't help. If they need two or three, then there's a chance.
Tom
Ufortunately they are looking for a whole house worth. Thanks anyway
Never heard of "antique looking" radiator covers. I do know of 2 kinds: metal and wood. ARSCO and Monarch make the metal ones (popularized during the mid-twentieth century when people started thinking of radiators as unfashionable). I can't recall the manufacturer of the wooden ones, but they can be made in raised panel or mission styles, I think. The makers of the metal covers indicate that they actually amplify the heat, while wooden ones inhibit the heat. Guess, I'd choose the metal ones, or better yet, sandblast and powder coat the old cast irons. Your customer would be surprised how good they could look with most decor.0 -
Radiator covers
can waste a lot of energy if improperly designed. Follow these links for more info:
http://www.heatinghelp.com/newsletter.cfm?Id=77
and
http://www.heatinghelp.com/newsletter.cfm?Id=115
It pays to wander off the Wall!
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Sommerville
Hey there is a place in sommerville Called ABC, they have a web site, http://interiordec.about.com/gi/dynamic/offsite.htm?site=http://abcdecorating.com/
I saw some of their work it looks nice. hope this helps.
Bob CAT0 -
here is one more
http://www.radiatorcover.com/
Michael Bleier
Able Distributors
www.abledistributors.com
"The Supplier That Works With You"0 -
A-1 plumbing supply in Cambrige MA can help you, ask fof Joel, good luck.0 -
Reduced output
Do your customer a BIG favour, and make sure you tell them how much their pretty covers are going to cost them.
The initial cost of the units is nothing compared to how much it will decrease the output over the next ten to twenty years. There are differnt designs and some will not decrease there output too badly. Some will actually increase by a small amount. The majority will decrease the output !
Poorly designed covers can drastically change the output of a cast iron radiator.
Scott
Even the best full covers
Will substantially alter the nature of the radiator. Not only will there be a major reduction the the direct radiation area available to heat the room, but the multiple incidences of this radiation (that work to spread the radiation throughout the space) will be lost.
Not to say that you can't still heat the space BUT the design becomes critical as it must enhance the CONVECTIVE portion of the radiator's output.
There have been some exceptionally beautiful (and expensive) European radiator "covers" on eBay recently. They essentially amount to an open, marble-topped, wrought iron or bronze console table installed around the radiator.0 -
Although it is near Cambridge, I think that A1 is in Somerville, Mass.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
