Elastemer sealing rings..Opinions
leroy
Member Posts: 6
Any opinion on elastemer sealing rings being used on WM hw boilers.Which is better in your opinion push nipples or rings .Any body have experiance with any leaks on WM hot water boilers and are they the only ones who use ESRings in between boiler sections.Thanks.
The boilers
I currently use do not have rings. That being said, I have installed hundreds of W/M boilers and have never seen one leak because of the rings.
Peerless uses them too.
I would not discount a boiler simply because of the "ring vs. nipple" debate.
Hope this helps.
Mark H
Rings
I've seen leaks in 66/68 steam boilers but not in FHW. Also the section design in the Gold series is an improvement. More machined surfaces, less wear from expansion. I believe they called it captured seal design. Hard to describe without a picture.0 -
peerless
most peerless boilers use steel push nipples, the pinnicle being the exception
chris smith
porter maine
love the ec/ect for stm, larger water volume than most for a given firing rate0 -
the best part about rings is if you have to section a boiler to get it into a basement all you need is silicone and a 3/4"socket and torgue wrench0 -
rings
Ditto on the other comments. I've used WM for years (hundreds of boilers) and never a leaker!!!!! They're great when you have to add a section for expansion or when the owner removes all the asbestos pipe covering and won't re-insulated. Can't beat 'em.
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 893 Plumbing
- 5.9K Radiant Heating
- 379 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
