Outdoor Temp controllers
JimHulgan
Member Posts: 1
I recently installed an in-floor in a shop. No living areas. Used mixing valves.What are pros/cons of adding an outdoor temp. controller to system.
the only.......
con I can think of is the up front cost. LOTS of pro's....variable speed lets you better control the slab output..less overshoot. Better fuel savings. less chance of having surprises (cold)when the temps drop fast.I 'll think of some more.kpc0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 926 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
