two stage t-stat
pat_3
Member Posts: 89
i dont have any experience using any two stage t stats .would appreciate some recomendations .two radiant heated bathrooms in the same home ,both will not meet the heat load with radiant alone.would like to use kickheaters for suplemental but only want the supplemental to come on when absolutely neccessary without shutting down stage one.(dont want a floor is not warm ,but t stat is satisfied call back) any help is greatly appreciated
It should work
if you hook up your radiant system to W1, or first stage heat, and your supplimental heaters to W2, or second stage heat.
When the T-Stat calls for heat, stage 1 will be made first, and stage 2 will only be activated if the temp drops lower with stage 1 running. I believe that there is normally a 2-3 degree differential between stage 1 and stage 2, but some thermostats have adjustable differentials.
If your supplimental heat is a different system; i.e. electric baseboard, forced air, etc., than your radiant heat source, you will need to use a relay to seperate the two low voltage control circuits. If this is the case, let me know and I'll email you a sample schematic.0 -
A nice two stage
would be the Wirsbo, also tekmar. in addition to two stage they have a floor sensor that allows a minimun or maximum setting for the floor. Nice large display.
Some models are programable,also.
hot rodBob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
