Copper fitting question
wflather
Member Posts: 22
Is there a copper or brass fitting, 3/4 or 1" that is a complete 180 deg sweep? If so, what is is called?
u fitting
U bend fitting
Return Bend
Bill, what your looking for is called a 180° return bend.It is not always found on the shelf, but all the major fitting manufacturers make them.0 -
U bend or return bend. Thanks.0 -
Bill,
It is a return bend, and is likely found in a refrigeration supply house. They are used on coils.0 -
Bill
IN case you have a real hard time tracking one down, the same thing can be accomplished with a 90 and a street 90. Just make sure you clean, clean, clean.
Scott
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
