hydrotherm boilers
Steve_12
has anyone had any problems with Hydrotherm HC boilers having too much heat in the firebox. I believe this may be a design flaw to try to get more effeciency. The roll out switch trips. The distributors answer to this was to replace the switch with one with a higher limit. The jproblem is that it gets so hot that it has actually discolored the jacket from too much heat. The boilers i am working with are 4 years old or less.
alignment
check the alignmment of the combustion chamber. I recall seeing similar prob a few years back. (shifted during shipping)
Terry
backdrafting
backdrafting
is the most common cause for what you are describing
I've seen a few case's in hog barn's where all the exhaust fans create a negative draft situation leading to what you describe.
Steve0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
