Labor Rates
TBK1
Member Posts: 14
Guys i would like to find out the average labor rates that you are charging or they are charging in your area. Here in the southeast the average seems to be 85.00 and hour. also do you charge a trip charge. thanks for the inputs!
Labor
It's not a good idea to be talking about labor rates and what others charge on a public forum.It could be seen as price fixing.
What I charge an hour is based on what MY overhead is,which may be very different than what YOUR overhead may be.You need to know exactly what your cost of doing business is and not be concerned with what others are charging.For all you know they may be deep in dept and about to go bankrupt.
this neighborhood
Average around here (suburbs of NYC) are between 65.00 and 95.00/hr with trip charges outside 20 mile radius(plus tolls in some instances). This was just the topic at a local supply house this week and this is what I was hearing.0 -
Overhead..................
is the thing that keeps you here or drives you out. I agree with you, Felcie. The "going rate" translates, in real life, into going out of business rate. I have different rates for each aspect of my business. Service, small contracting projects, larger contracting projects, diagnostic fees, design fees, etc. Each area differs in the amount of billable hours I can produce per week, hence the different rates. Also, net profits will vary with each project or service.
The first thing you need to do is forget what everyone else around you is charging. Then break down your business costs and work off of those numbers.
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
The guys are right, you have to be careful......................
when discussing going rates. More important however, is that you really do need to know what it is costing you to "turn the key" in the shop door every morning. It is a hard row, but it will be eye opening and liberating. You gotta get Ellen Rohr's 2 books on this subject Mad Dog
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
