Dunkirk D247 Boilers with CSD-1
James_2
Member Posts: 24
Has anyone out there been having problems with the Dunkirk D-247 boilers with the CSD-1 Ignition module made by Channel Products Company. This unit has a manual reset switch to reset the module in the event of a flame failure. I have several boilers which have constant nuisance shut-downs which is driving my customers crazy. Please let me know... Dunkirk has been dragging thier feet on this one. Seems I am the only one having problems... Any one else having problems?
Glad you posted this
I plan on using a 247 steamer with CSD-1 in a few months. I'll be watching this thread closely.
Boilerpro0 -
D247
Did you ever get an answer on this; Ive got the same problem with a D247.0 -
D247 ignition module problems
One of our Burnham wholesalers sold a 4 module steam (1600 I believe) when our delivery on a comparable Burnham was going to be a little long for them. One module failed very early in the game, a second about a week later, all while they were unable to find any locally.
The wholesaler and contractor replaced all the ignition modules and pilot assemblies with Honeywell components, and all are working fine now. I dont know if they ever did find out what the problem was with these original modules, but the school has been warm ever since.0 -
D247 Ignition Problems
Jim Benson @ ECR (engineering)is working on this. They say that the Channel Products Mark IV is not self grounding. We will be installing a ground wire from the pilot bracket directly to the ignition module. I guess at this point try this and see what happens.0
