Ultra-fin floor heating
Joh n Brickey
Member Posts: 43
Has anyone used the new Ultra-fin aluminum heating systems. I saw them at the ASHRAE show in Chicago and the guy was real convincing. I have an infloor job coming up real soon and I'm considering using them.
ultrafin
I've had them in my home now for six years and would not use them again. water temparatures needed to get enough heat from them is far to high. If you have any carpeted floors you will not get enough heat to achieve more than
68 degrees. I had to install baseboard in my bathroom to stop that zone from being on all day long. In other words don't please install these, install a proper floor heat system.0 -
What temperature water are you using. They recomend 180 degrees.0
