Btu hydronic mania! (PAH)
hot_rod
Member Posts: 26,631
300,000 Btu boiler. 180,000 Btu load.
Run it 24/7 with constant circ. in a 2" loop that stretches around the home. Maintain 165/160 in the secondary loop by way of a 4-way mix. Keep the boiler pinned between 210/195.
Let's add a great big oversized 6.5 amp circ while we're at it and forget any type of support - that's what the flex connectors are supposed to handle - right?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=98&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Well ...
... the house was warm, so it must've been working, right? :-)0 -
Looks like...
the typical under designed/over engineered systems I run into on a daily basis.
What ever happened to common sense??
I sometimes wonder...
ME0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
