Pump flanges
Tim Davis
Tim Davis Member Posts: 21
I am looking for flanges with built in isolation valves,can any one recommend a manufacture.
PS,for small wet rotor pumps
Thanks, Tim
  • Mike Kraft
    Mike Kraft Member Posts: 406
    I have used...........
    Grundfos and Taco's.Both with great success.They are bronze body and have a 5mm allen set to open and close.They make for a very clean install.
    cheese
  • kevin
    kevin Member Posts: 420
    Webstone...
    my supplyhouse carries them.(GRANITE Group in No. New England)They have a true ball valve handle... no messing around w/ a screwdriver.. Punch them into a search engine ...see what you get. kpc
  • J.C.A.
    J.C.A. Member Posts: 349
    I like the webstone' s
    The Taco shut-off flanges look nice , but the valves rarely get used and seem to fail at an alarming rate (around here anyway) when touched .
    IMHO ...Nothing beats a nice freedom flange with nipples and a ball valve top and bottom . Cuts a pump switchout time to a minimum with little mess . No muss....no fuss , positive shutoff rules ! Chris
    hot_rod Member Posts: 23,771
    or you could
    buy these Jomar valves, and screw on the "color" flange of your choice. Available in sweat or FIP, 100% full port, and most importantly they have stem packing nuts!
    They also make a nice transtion from cast boilers to copper, fitting!
    On the lower left is a Watts valve with a purge port. Take a few thousands off the o.d. of a 3/4" Taco freedom flange and it will sweat inside a 1" ball valve. Nice for non ferrous systems also.
    Nothing more frustrating than an inexpensive iso flange that leaks around the shut off screw, after a pump changeout :)
    hot rod
  • Tim Davis
    Pump flanges
    Thanks for your inputs.
    Tim
  • Leo
    Leo Member Posts: 770
    A good isolating flange
    www.webstonevalves.com
