pex-al-pex or pex
antman
Member Posts: 182
I was wondering when deciding on the use of pex for supplying hot water convectors, if supported properly is there a problem with using Wirsbo hePEX. I have read here that the use of Multicore is better for this because less expansion of the tubing.I have alot of little coils of hePEX I would love to get rid of on this job. Any thoughts would be greatly appreciated.
Thanks, Ant
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=239&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Thanks, Ant
By all means
use Pex-Al-Pex.
No sense in taking chances!
Mark H
If it's.........
exposed, I use MultiCor. If it's hidden or I need to use ProPEX fittings, I use PEX. Another factor is temperature. I don't run PEX, for the most part, over 140°. Over 140°, MultiCor is my first choice.
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
HePex
We use Wirsbo HePex for heat loops on all our baseboard systems.I think pex-al-pex is a better choice but the fitting connection for it makes it more costly and difficult to connect.If Wirsbo had a crimp ring or something other than the compression type fitting I would switch to it.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
