What kind Pipe?
JM_2
Member Posts: 108
Should i use whae adding a "T" for a Flush valve on my steam return lines, "Black Pipe" or "Galvinized Steel" and why. These are the only options avail at my home center.
JM
JM
Black pipe should be used since galvanized can flake into the steam system and react with the hi-temp steam causing clogs in the air valves. It usually flakes due to the expansion and contraction of the pipe during the steam cycle.
-JLG0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
