CAST SECTION PROBLEMS??
bryan_4
Member Posts: 5
Is anyone else running into section problems with Weil McLain boilers CG series(end of 99/beginning of 2000)? Had one the other day that 5 of 7 sections were cracked (all middle sections on a packaged boiler)with one section having a large chunk missing, and now got my second call with a cracked section (not sure how many yet but it's an 8 section boiler) same series.
Hmm.
Could the unit have had a run in w/ some internal ice? Been real coooold this year. Might want to check the rest of the system.
Weil is normally very responsive about inspecting the boiler on the job, or if necessary, at the plant.
Good luck.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
