One pipe steam heating
Joe_8
Member Posts: 32
Joe,
How long is the horizontal run for the first floor? Developed length of pipe matters, especially horizontally.
Also, is the pipe pitched up all the way to the radiator? Lastly, could the steam radiator valve, or the supply line be obstructed in any way. Sometimes these valves have leather washers that have been oversaturated and expanded to the point of closure.
Joe
Joe
I have a one pipe steam heating system with two 2 inch feed lines. I have a 2 inch riser that handles 3 radiators; first second and third floor. Second and third floor radiators get hot with venting on lowest setting. First floor radiator does not heat at all even with venting open all the way. Second and third floor radiators are supplied by vertical riser. First floor radiator is on horizontal 2 inch pipe with 1 inch supply. This system is unusual as main feed lines pitch up from boiler supply with no return loop. I'm assuming condensate returns back towards boiler through main feed line. As a test I removed the first floor radiator and opened hand valve while the system was running and even though second and third floor radiators and riser were hot and boiler was running steam did not come out of the open valve. I do not understand please help!
could be underfired boiler
could also be dirty water, or missing insulation on the piping, or a blocked pipe or fitting, as mentioned.
Noel0 -
Joe, you have a counterflow system. read about in Dan's book
http://www.heatinghelp.com/shopcart/product.cfm?category=2-3
Ant
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
