Honeywell PC8900
Glenn Harrison
Member Posts: 405
Try going to this website:
<a href="http://hbctechlit.honeywell.com/" target="_blank">Honeywell Technical Literature</a>
Enter PC8900 and a list of available service and install literature will pop up that should have the info you need.
I beleive that you have to ohm out the outdoor sensor using a chart that states what resistance there should be based on the outdoor temp. You will more than likely find either a weak connection in the sensor wiring or an inaccurate sensor.
Glenn Harrison, Residential Service Tech
Althoff Industries Inc. Mechanical and Electrical Contractors
Crystal Lake, Illinois
<a href="http://www.althoffind.com" target="_blank">Althoff Industries website</a>
Outside Temp Question
I've been all over the Honeywell site and can not find the answer to my question.
When the outside temp is read and displayed on the Honeywell PC8900, how accurate is the reading? Is it +- 1 degree, or better?
If the complaint is that it is off, how can it be checked?
I assume that it is not adjustable, correct?0 -
Good question
Did you ask the rep?0 -
Althoff Industries website0 -
Thanx!
Thank you, I had not found that access to the tech documents.
I book marked it.
Thanx!0 -
Your welcome, and good luck. (nm)
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
