Pex lines noisy
John G. Merritt
Member Posts: 140
Guys:
Got a job with all Pex tube throughout a very large home. The complaint is noise from expansion/contraction.
Will expansion joints at the boilers help with this?
The tubing is under floors, up inside walls, etc.
Never had this complaint before. Any ideas???
John
John
Would you please tell us a little more about the system? Maybe some pictures.
Is it injection or mixing valves? what size pumps?
Jamie0 -
Noise
Do you have any re-set on the system ? The large temperature swings really make this a problem. Constant circ. Helps eliminate this also.
Years ago I had a problem with this and added expansion loops to the pex before the risers in the basemant, it helped take up Some of the expansion.
Pex-al-pex is the way to go.
Scott
Pex noise
Years ago I had that problem on a clip-up system.Ended up being the clips I was using.Check to make sure they're compatible.Also check if the lines are bundled together to tight.
Good Luck
Brian0 -
"very large home" makes me think perhaps your loops are a lot longer than normal perhaps? That would explain why you might see it here and not on other jobs. For long runs in dry installations I usually try to break them up into two separate loops. A bit more work on the install but more expansion is taken up by more loops! 1.1"/100feet/10deg delta T adds up fast when you have 50 foot straight shots down a long joist bay.
As someone else noted, reset control can help this a lot if you don't already have it.0 -
expansion noise
i have that noise in my house from the 2 bays that have extruded aluminum plates. i don't have outdoor resetTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
expansion noise
i have that noise in my house from the 2 bays that have extruded aluminum plates. i don't have outdoor reset. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Pex noise
Guys:
This is a Pex system, using Mixing valves, and fairly tight bundles of 1" supply, runs are about 40 to 50 feet before they go up into the walls of this monster 2 million dollar house. Has a snow melt also, all (6) patios.
Don't know the Circulator sizes at this time.
Have not spent enough time to check everything out yet.
I just wondered if Expansion joints would help stop the noise. (Has outdoor reset also) Customer installed most of the tubing himself. (Nightmare) John0 -
pex noise
I discovered the hard way that barrier pex tubes when rubbing against each other can make a good deal of noise. If your tube is barrier style, this could have a lot to do with the problem.
Bill0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
