Radient floor heating systems
N_carolinian
Member Posts: 5
1)Cost? (charge by square foot or other dimension) 2)maintainance? (Need a lot of maintainance) 3)durability if outside? (how long will it last)(will rain or freezing temperature damage it) 4)can it even be installed outside? 5)can it be installed into concrete? 6)can it be installed into majo bridges or overpasses?
An outdoor radiant system is usually called "snowmelt" heh...
What exactly are you trying to do?0 -
bridge install
Try this link: http://www.igshpa.okstate.edu/ They were running a test on just that question.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
