Hvactv
Lowell Thiesen
Member Posts: 6
What is the secret to loging on this site? Why do we need passwords anyway? Am I the only one having a problem with this?
not alone
I tried myself a few times and it kept freezing my internet explorer up. Anyone know why?0 -
I'll try to help
By offering the following information.
Watching video and listening to audio on your PC can be a technological challenge, especially for older computers on dialup connections. Lets start with the basics. If your computer is more than 2-3 years old it is important that you free up as much of its resources as possible. Be sure you have NO other programs running in the background. Anti-virus programs that check incoming data, e-mail programs that check your mail at regular intervals, and any other programs that use up RAM or CPU cycles will degrade or interrupt performance, especially on older, less powerful machines.
PC or Personal Computer for HVACTV we recommend at least a Pentium 1 class processor at 200MHZ or above, and suggest a Pentium 2 class at 300MHZ or above for good results. Your operating system can be Windows 95 or above, but different systems require different versions of Windows Media Player (WMP for the rest of this document). You also must have a sound card and the volume turned up, and no other software running at the same time. You can download WMP at http://www.microsoft.com/windows/windowsmedia/download/default.asp
Dialup Internet Connection You must have an Internet connection and at the least a 56K Modem. A 56K modem on its best day might hit 40K if all systems are running perfectly. Remember, you are using a regular telephone line. Sometimes you can call across the country and it sounds right next door and other times calling across the street can sound like calling the space shuttle. Your modem will occasionally have the same problem. For a good page to check your connection speed try DSL Reports. You can find DSL Reports at www.dslreports.com and go to the Tools page and select speed test, and follow their instructions.
BroadBand Internet Connection If you are connected to the Internet with a cable modem, DSL, or your company network you are on broad band. You will see a larger picture than on dialup, and will notice better sound quality, especially on music. This connection is more reliable. The HVACTV.com broadcast page automatically tests your connection and selects the stream best suited for your connection. If you wish, you can switch streams using the hot link (BroadBand/DialUp) above the video image. You can test your connection speed at DSL Reports, they are an independent site that has a number of tools to test and tweak your Internet connection for free.
Browser .It is truly unfortunate, but we can no longer support Netscape in any version. At less than 6% of the market and with its own idiosyncrasies that require almost an entirely parallel website devoted to Netscape alone, its just not worth it at this time for us little guys. Internet Explorer from Ver. 4.5 up comes with the WinMediaPlayer plug-in installed and ready to go. It looks like Billy Gates won this one folks.
A Word about AOL . America on Line is NOT the Internet, it is a very large, but still private network that you log into. AOL makes every effort to keep you within this private network behind their proxy server where they can entertain you and sell you stuff. While valuable to protect children from evil, and very easy to use, it is not a business-class Internet connection. Because we cannot control how AOL handles our data on their network, we cannot always guarantee a top quality experience
Measuring your Connection to HVACTV.com When connected to a live stream or an archive, place your cursor over the video image (or the black box where the video should be), and RIGHT click. A drop down menu will give you a series of choices. Under Statistics check your Bandwidth This is the true connection speed that you are receiving from our server. If you are not receiving video, it will indicate an Error Code. This code can be helpful to HVACTV.com tech support in diagnosing your problem. You should get 30K or more on dialup, and 70-93K on broadband. To jump to the HVACTV archives use: http://www.hvactv.com/hvactv/new_site/video/hvactv.php and select Previous Webcasts.
I get Audio but no Video Ninety nine per cent of the time this is because you have an older version of WMP installed. Microsoft is always improving their audio and video compression/decompression (codecs) software. If your audio codecs are compatible but your video codecs are not, you will receive the compatible portion, in this case the audio. The solution? Download and install the latest version of WMP (click here), or go to:
I get Video but no Audio Because the video rides on the audio stream, unlike the scenario above, it is impossible to receive video without audio. Check your computers volume setting (usually a small loudspeaker shaped icon in the lower right corner of your screen), move all sliders to the uppermost position. Be sure none of the inputs have the Mute box checked. No volume control in the lower right corner? Virtually all computers now come with a soundcard, but many corporate office systems have the sound card disabled to prevent annoying your officemates. Call the IT dept. If you have external speakers be sure they are powered up and the volume is up.
I Dont Get Anything at All If you get no audio or video, and you have no VCR like controls in the upper corner of the HVACTV Broadcast Page, then either you dont have Windows Media Player installed, or the plug-in is not properly installed in Internet Explorer. Go to the MS Download Page and follow the instructions. If you are using Netscape 6.0, this could be your problem. Due to the large number of incompatibilities in 6.0, and the age of the last reliable Netscape browser (4.7) we are not offering tech support for Netscape users at this time.
If you are on a corporate network behind a firewall and/or a proxy server you may need to have the IT dept. allow you to pass both video and java applets through the firewall/proxy server. Please have your technician contact us (below) and we will be glad to assist.
Everythings working but .The slide area and the chat box are cut off. When designing a web page its hard to make it look good on every possible size monitor at every possible resolution. On smaller monitors (up to 15) Select Start>Settings>Control Panels>Display>Settings. In the lower right corner of that panel should be a slider set on 800x600. If its on 640x480 move it to 800x600. Return to the HVACTV.com broadcast page (you can try this while watching an archive and get setup for the next live event in advance). If some of the elements are still cropped, go to View(in the browser bar) and select Full Screen. This will eliminate the borders and menus that you will not need while watching. To restore click the upper right corner icons for the view you want. On larger monitors its the same drill, but the slider will go up to 1024x768, which is recommended on newer, larger monitors. Expewriment with these settings, you cant hurt the hardware, and you can always change it back after the broadcast.
Still no luck? HVACTV is a small, customer service driven company. If the above suggestions dont get you up and viewing video in a convenient amount of time just call, toll free, at 1-877-289-7553, or e-mail to RicM@hvactv.com. There are no long ques or bad hold music. You can talk directly to the guy who put this all together and he will walk you through configuring your system to enjoy and learn from www.HVACTV.com.
Your friend in the industry,
Alan R. Mercurio
Oil Tech Talk0 -
Thanks for helping out Alan
Lowell and Kevin did you ever get tuned in? If not when you get up and running it is in the archives.0 -
No, I was not able to log on, I was getting the invalid password message. I was using the password that I signed up with so I do not know what the problem is.0 -
Lowell get in touch
with Ric Murray, Alan Mecurio gave his number. He will help you out I am sure. Sorry you missed the program but it is in the archives.0 -
