Loosen old fittings
Donald
Donald Member Posts: 7
I have a job that I will be replacing several hundred steam traps. Does anyone have any recommendations on how to loosen the fittings. (i.e what kind of spay on rust remover).
I remember someone telling me, that when you have the two pipe wrenches on, apply equal pressure, have a second person hit the knob end of the pipe wrench (right behind the jaws)with a hammer. This sends a vibration into the fittings. (Don't use an aluminum pipe wrench). He also used to put one hammer on the back side of a fitting at tap the fitting with another hammer. I know if there are any cast iron fittings I can break them. What about adding pipe extensions to the pope wrenches.
  • nick z.
    nick z. Member Posts: 157
    Spray
    there is a stuff called "Nut Buster". White can with red and yellwo lettering. Found it at Wal Mart, and auto supplies. This stuff really works.
  • kevin_5
    kevin_5 Member Posts: 308
    Donald, I've never loosened a lot of steam traps, but have loosened a lot of rust in my time. "PB Blaster" is the best penetrating oil I have found. Some people swear by "Gibbs" which is much harder to find and more expensive, I haven't really tried it much.
    Torque, Heat, Impact, and Chemicals are the 4 ways to break something loose, so yes I would try a little constructive hammering. I would get something heavy like a big sledge hammer head or big auto body dolly that you can put on one side of the union, and a lighter hammer that you can give some quick sharp raps with on the other side.
    Since you are doing so many, it may be very beneficial to use a vibrating pneumatic muffler gun. You can buy a hammer insert for this tool, and it will do amazing things in the way of breaking rust loose. Just an idea. Kevin
  • kevin_5
    an idea Donald,
  • tim from Reed Wright
    tim from Reed Wright Member Posts: 113
    trap replacements
    amazingly enough, we just get in with our wrenches and usually the come out. If we get a tough one we have to sometimes cut out spud from radiator. Generally though this is not the case
  • jeff_25
    jeff_25 Member Posts: 110
    traps
    are you rebuilding or replacing if rebuilding try to use a big socket or a 15 or 18 in. crestent wrench and try not to screw up the cap unless putting a new cap some times a lite rapping with a hamer helps if installing new traps on a rad. i have had goog luck using kipex pielers best when new you dont have to cut the nut off good luck jeff
  • Donald
    Thank you for the help
