Oil Chimney Vent Help.
Warmfoot
Warmfoot Member Posts: 127
I am installing a Oil chimney in a new home. They have built a chase up off the roof and we will be installing the chimney (All fuel Metalbestos SSII) inside of it. At the termination, they have built a cover with a large stone. to support this stone, two sides (East & West Sides)of the chase will be solid and the exhaust will only vent from the north & south sides. Does anyone see a problem with this type of installation? I have been unable to find my mechanical code book and was hoping someone would be able to help me. I have a drawing, but my scanner is down right now. This may not be a big deal, but I want to be sure.
Ernie Bogue
Master Hydronics LLC
PO Box 779
Keyport, WA 98345
(360) 394-2049
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=178&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Alan R. Mercurio
    Alan R. Mercurio Member Posts: 588
    Ernie, I would say providing your chimney liner is properly sized for the BTU Load (and I'm sure it is) And the height meets the 3' above any pitch & 10 ft from any obstructions you should be fine.
    Hope this helps.
    Your friend in the industry,
    Alan R. Mercurio
    Oil Tech Talk
