Replacement pipe design
ta finnegan
Member Posts: 121
For this I would recommend primary/secondary and zone with circulators.
If the iron is o.k. then leave it be, just flush and clean everything thoroughly when you're done.
When copper touches iron it is a no-no. Dialectric transitions are code in my area, but seldom used.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=251&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Design of replacement hot water pipes
I have a 2 family building with a gas hot water boiler and large black iron pipes that were designed for gravity circulation, although a pump has been added. I want to replace them to make space and to seperate the two apartments into zones.
Can someone recommend a reference for designing the new circuits? Also, I'm debating whether to use black iron or copper. If I do use copper, should I use dielectric unions to connect to the 2nd floor black iron risers?
Thanks0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 925 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
