Steam supply to flammable storage tanks
Alaska Joe
Member Posts: 37
Can anybody tell me what codes, (NFPA or otherwise), governs the steam pressure, piping, and or safety devices required on flammable storage tanks (lube and fuel- 5,000 gallon type) that are heated with steam? I thought that such systems were limited to 15psi or less, but what scares me most is if things went bad, having a slug of lube and or waste fuel oil finding its way back in the condensate return to my huge steam boiler system. Train men please chirp-up!
Flamable storage tanks
ASME, ASHRA, and NFPA are a good reference point to start with.
Jake0 -
NFPA 30 and 31
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
