Brilliant new tool!
adambuild
Member Posts: 422
I've been using a new tool that I found in the back advertising section of P&M about a year ago. It's called the Ace Cut-N-Clean. It's a device that I mounted on my Ridgid #151 copper pie cutter. When you turn the cutter to cut your pipe to the desired length, a small, durable plastic "cradle" holding a small piece of "Scotch-Brite" cleans the end of the pipe! No more emery cloth! It's really an incredible time and hand saver! You can order on the web at "http://www.plumbingtools.biz" They make different models for different brand/size cutters. Good luck and happy cutting!
- 120 Geothermal
- 169 Indoor-Air Quality
