2 pipe vapor presure
Re: Replacement WM boiler for residential 2 pipe vapor system
Problem: New Boiler is flooding
1. Re: Hydronics Institute - Installation Guide: Residential hydronic heating - Guide 2000, Part 10page 10-38. "..It is critical to operate vapor systems at no higher than 1/2 psig." What is the correct operating pressure for this system? (The Owner has always operated the previous boiler at 5 psig?!)
2. RE: Hydronics Institute - Installation Guide: Residential hydronic heating - Guide 2000, Part 10 page 10-39 shows a distance of 12" below boiler water line to the top of pipe with check valve 6.
- Is there a critical distance from the boiler water line to the top of pipe with check valve 7?
- Is there a critical distance from the top of pipe with check valve 7 to the top of pipe with check valve 6?
- Is there a critical distance from the top of pipe with check valve 7 to any other point in the system?
