pump position
pat_3
pat_3 Member Posts: 89
is there a prefered position for circ pumps,ie:horizontal ,vertical.i've read in manufacturer literature that either way is ok as long as motor is not vertical ,but was curious as to other opinions.usually all my circs are mounted horizontal,but latly i've been getting jobs without the room to do so.your opinion is apprieciated.
  • kevin
    kevin Member Posts: 420
    you're.....
    correct about the motor position.... either way for the mountimg can work. It is best to keep the wiring connection on top if all possible. kpc
