Ergomax as buffer tank
Wayco Wayne_2
Member Posts: 2,479
I"ve never used an Ergomax but have read that they can be used as buffer tanks. How many taps do they have for this purpose and how large are they. Thanks in advance
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
No responses for this question
Is there an elephant in the room no one is talking about?? Is there a problem no one wants to discuss?? Is it just a plain bad idea?? I got a bad feelong about this.
Ie Ergomax still around?
the issue I see is not enough taps into the boiler side of the tank to allow paralel piping arangements. If series is an option they would work, in my opinion.
I have seen a Thermomax brand that looks similar.
Try this article for ideas.
http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,78589,00.html
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
same as hot rod
The ergomax needs another set of tappings. As is, you either have it piped in series with the boiler, causing stored water to be pumped through the boiler heat exchanger even while burner off (quickly wastes heat) or you have boiler pump and heating pump fighting each other.
Bill0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 987 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
