Breeching Insulation.....Boilerpro
Why not call a manufacturer like Certanteed, Owens corning etc.
2" thick calcium Cabonate should do the trick. That stuff has been around as long as asbestoes.
It aint dangerous either.
jake
jake
Working on a 1.7 million btu multiple boiler replacement heating plant. Have an existing 18 inch single wall galvanized breeching that looks to be covered with asbestos and it will be abated. Looking for some leads on replacement insulation. Have already priced B-vent (16 inch since that's all that is needed) and at 50/ft and 100 per fitting, looking for a more economical alternative. Adding 2,500.00 to the bid for the vent material seems rather steep. I use B vent to lined chimneys on nearly all jobs, res. or com., but this is getting a bit steep. any help would be appreciated. Thanks all!
Boilerpro0 -
insulation
Perhaps a fiberglass blanket product. I've seen a fiberglass quilt material- padding in fiberglass cloth-aslo called lagging. It was used on 1200* steam lines and on diesel generator exhaust on the ship I was on in Navy. It was fabricated on board in a shop for valves and other odd fittings and was laced up with wire like a sneaker on the pipes.0 -
Dave, can't the chimney installers get a ceramic wool
that is high temp?0
- 120 Geothermal
- 394 Solar
