Master of the Obvious....(hb)
hot_rod
Member Posts: 25,397
Its things like this that will never let me get too full of myself! Remember my Uh-oh thread from last week? I have resolved the issue with the building cooling off over night during extreme weather. Yesterday, I spent 90 minutes going through every aspect of Viessmanns Vitotronic 200 control system. Heating slopes & Shifts, timer settings, sensor readings and error logs. This is one very cool control. Naturally, with Viessmanns commitment to quality, there seemed to be nothing wrong. I was at wits end. The home would catch back up in temperature in the morning by 11:00AM, proving my boiler & system are not undersized. The system acted like it was going into night setback even though every piece of hardware told me it wasnt. Then it hit me square in the face. So obvious I feel stupid. The issue revolves around the lower level, which is a walk-out basement with 80 of exposed walls a many square feet of glass. Since they havent finished it off yet, they have the thermostat set back to 62°. Well, since it has all of that exposure, in the middle of the night during extreme conditions the slab radiant calls for heat. Remember, the slab is virtually cold with the thermostat set to 62°. You guessed it. The slab soaked up every BTU the Vitola could generate before it started to warm the slab, dropping boiler temps down to less than 115° for hours. Lets see
. 2° outside with the radiant designed for 140° (ThermoFin joist bay) and the baseboard for 160° at 10° outside. Wonder why the building goes cold? Im an idiot, thats why!
Warm Regards,
heatboy
"Expert in Silent Warmth"
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=103&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Warm Regards,
heatboy
Hey!
Don't give yourself such a hard time, heatboy.
That's our job!0 -
That's funny, your reason that is
I actually laughed out loud at the end of your message. I think I'm going to steal that answer for when I make mistakes (happens all the time, it is life). Next time the boss asks why something is wrong, I'm going to answer, "I'm an idiot, that's why."
Don't feel bad, we all miss the obvious, fundamental things.
bN0 -
Thanks !
Hey HB! Thanks for learning a lesson for all of us........
That one is definitely getting stored in the memory bank.
Jamie0 -
Say Heatboy, Theres a way to help prevent this
I suspect that you are using a standard fixed temp mixing valve on the slab. Not familiar with the Vitrotonic, but I'm guessing it is a full reset setup. If you install a fixed three way valve to meter the amount of hot water mixed with the cold water returning from the slab, it will limit how much heat the slab system can draw from the boiler. Will have a picture of a home set up with this concept soon, but not now. Probably the fixed water volume three way valve is a better setup with reset than the standard fixed temperature mixing valve just for this reason.
Boilerpro0 -
Sometimes it pays....
to get out of the boiler room (I think Dan Holohan said that somewhere)and wander around.
Sometimes you have to do that just to get the cob webs outa your head. I know I do!!
Warm Regards, heatboy
Your associate in "Expert in Silent Warmth"
(Have you figured out how it is that I can do that yet???)
I think Yatesey knows...
ME
Living the hydronic dream0 -
One big difference...
...an Idiot wouldn't take the time or energy to figure it out. Your no idiot...your a large cut above the average.
Ignorance can be cured...stupid lasts forever.!
Good job,
Art0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
