Vitodens Install (Pics)
kevin
kevin Member Posts: 420
is that light blue pex on that manifold? Who makes that?kpc
  • John_21
    John_21 Member Posts: 34
    Vitoden 200 install (pics)
    Here are a couple pictures from the last two Vitoden installs that I did. I took a couple pictures to show the the low loss header w/low water cut-off installed. Both systems are presently purring right along.
    John White
  • Henry_4
    Henry_4 Member Posts: 59
    Nice use of space
    question:
    I notice that you are using one system pump and four aone valves. What are you doing to balance the leader lines to your point of use?
    Henry
  • John_21
    Pex
    The blue pex is for water(blue for cold, red for hot) it is made by Zurn Quest. Saves time on water piping by color coding. John
  • John_21
    Balance
    The zones with valves are all baseboard or toespace fan coil type of heaters. There is a 3 way mix for the gagage radiant. This a remodel, addition garage with master bedroom above. The 1542 only works when the is a call for heat by any one of the zone valves. Balance has not been a problem. John
  • Paul Rohrs_2
    Paul Rohrs_2 Member Posts: 171
    Quest Pex
    I am familiar with quest pex, is that an oxygen barrier tube?
    PR
  • John_21
    Pex
    They make both One for water and one for heat.
  • GW
    GW Member Posts: 5,065
    Very nice
    We just did one too. What size is this? Does this unit not have the internal circ?
    Gary
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • John_21
    Size
    The picture’s are of two different models the first is 11-42 and is set up for a future snowmelt. The other is a 15-60 that has 21radiant zones, 1 fan coil, 1500sq.ft. Snowmelt, and 1 indirect w.h. Will send pictures of that system soon.
    John White
