Ash accumulation - superheater
Jim Davis
Member Posts: 305
Sugar cane and corn are two fuels I haven't tested, but I would think sugar cane woould burn similar to wood. Worked on a couple of commercial wood chip equipment that were having a serious ash build up. Used a CO tester and found that this was a critical reading for air adjustments. By keeping the CO below 100ppm the ash quantity drop about 75%.
Just a suggestion. Do you have any other Comustion Readings?
Dear Forum Memebers,
As we have 160 tonnes capacity, 22 Bar , 300 deg Celcius Bagasse fired(sugar cane after removal of the juice)in our factory.
As the boiler is working fine in all aspects , except building of the ash in the superheater.
As we are maintaining the boiler Furnace pressure minus 3 kpa, and forced draft pressure 2.5 kpa, and secondary air pressure 5.2 kpa.
As we could not able to operate the boiler more than two weeks prolonged time, as the ash accumulation takes place in the super heater. As we don't have the soot blower which can clean this ash . Is there any way to avoid this ash build up at the super heater coils with out installing of the soot blower.
Yours comments on this issue is highly appreciated.
Thanks & Best Regards,
Ravindra.
mullapudir@hotmail.com
NAT-L-QH@HN.VNN.VN0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
