No heat
ck54
ck54 Member Posts: 1
I have radiator heat (or hot water heat, i'm obviously not a plumber) and ive tried bleeding 3 of my radiators, to no avail. I do not even hear air escape when i open it up. Does anyone have any clue what could be my problem? Ive checked all valves and there should be water running to these radiators. If anyone can provide some insight, it would greatly be appreciated.
  • MIKE6
    MIKE6 Member Posts: 102
    rads
    Sounds like the water feeder valve is not allowing water into the system.
    Mike
  • Bob Cat_2
    Bob Cat_2 Member Posts: 14
    What do your radiators look like?
    Are you sure you have hydronic heat? how many pipes go to the radiators? I'm not trying to belittle you I had a customer last week tell me the same story and she had steam heat. Do you have circulators in the basement at the bolier? What is the pressure in the boiler? you'll need atleast 12-15 psi to get the water to a second floor. You said you don't hear air do you get water? I could use a little more info, like are there valves to each radiator or does the piping go from onr radiator to another with no valves? tell me as much as you can about your system.
    Bob Cat
