can a humidifer be installed on a \"magic pak \" furnace?
frank s
Member Posts: 64
it is possible, if you have enough rom on the supply duct, then you'll have to run a by-pass pipe to the return duct or the side of the blower cabinet. You may want to consider another type of humidifier that works independently of your heating system, this way you will always get the moisture when you need it. Hope this helps '
Frank
Frank
I it possible to put a humidifer on a magic pak furnace?. It is an all in 1 unit ( heat and ac ). I live in a condo and it is in a closet. the hot air goes out from the top and the cold air return is under the floor and enters the unit from the bottom. Is it possible to install a humidifer and where? thanks!
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
